Well i'll make this short at least as short as i can. About two years ago i snapped my timing belt and bent the hell out of my valves. In my spare time since then i have slowly rebuilt the head and reassembled the motor. After getting the exhaust all back together saturday the time came to finally add fluids and start her. So problem it didn't start. I know the fuel pump works because the fuel absorber was spraying fuel everywhere (i replaced it with rubber fuel line). I know i have spark because i put some gas directly into the cylinders and it fired but could not sustain running. When it cranks it cranks hard but just no fire. I'm trying to get a list of things to together to try and sort this out and any suggestion that anyone here has would be a tremendous help. '87 325is
Thank you,
Josh
Thank you,
Josh
