Where does this go?
  • Evilsmith
    • 171
    Where does this go?
    This hose comes off the charcoal canister and is paired with the ICV connector. I looked all over the throttle body and cannot remember where this hose came off of. Does anyone happen to know?
    Vert build - http://www.r3vlimited.com/board/showthread.php?t=167264
    See your post on bimmer forums
    • Tree18is
      • Mar 2004
      • 2703
      im sure you allready got it on there.
      wtf is that thing?
      • Liam
        • 753
        Bottom of the throttle housing, It's the evap. canister purge valve line.
        I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
        • bmwlover0725
          • 36
          when Liam says bottom, he means far in. put your hand under the throttle body with the engine cold and feel for an empty hose fitting coming out. Just put that in and you'll be all set.
          I'm guessing your check engine light comes on at idle without that plugged in.
          • SpecM
            • Oct 2005
            • 4531
            yea, you'll get a nice little vac leak w/o it too
            OP: it plugs in right behind the TPS
            1989 cirrisblau-metallic 325i
