wining noise thats consitant at idle--but goes away when clutch is pressed???
  • Spieler209
    • 120
    Is this the main engine bearing... or clutch.. Noise goes completely away when clutch is pressed in... Clutch grabs fine??
  • ADEN
    • 620
    clutch release bearing
    • bmwlover0725
      • 36
      throwout bearing. try to fix it before it totally fails because that can end up being a nightmare...
      • kronus
        • Apr 2008
        • 13032
        Nope, all wrong. You're hearing the Getrag rattle, which is a mostly normal noise that all Getrag trannies make to some degree or another. Search "Getrag Rattle" for more info about it.
        cars beep boop
        • Fidhle007
          I can fly, motherfucker
          • Oct 2005
          • 7209
          I disagree, the rattle will be more of a rattle and highly prevalent with a lightweight flywheel but a high pitched whine or screech which changes (or in the early stages goes away) when the clutch is disengaged is the throwout bearing. Get your car to the nearest BMW specialist ASAP and do everything you can possibly think you might need while the tranny is out. Clutch kit, rear seal if leaky, input shaft seal... You get the idea!
          Good luck!
          '89 325is S50 Track Montser
          '04 X5 Daily/Tow Vehicle
          http://www.avarestoration.com
          http://www.myspace.com/brendanfiddle
          Click here if you want to be my zombie slave...
          http://www.youtube.com/user/Fidhle007
          • ethirtydavid
            • Jan 2008
            • 2331
            saying it is 'getrag rattle' over determining the specific mechanical part in question (throwout bearing) is like saying a car has 'a lot of pep in it', rather than 'it has 170hp'.
            • kronus
              • Apr 2008
              • 13032
              Good luck!
              Yes, I agree about the throwout bearing. However, he has a noise that's there at idle and goes away with the clutch in. That means that when the input shaft is spinning with no load, it rattles around a bit, hence the getrag rattle.
              cars beep boop
              • e30this
                • 3580
                Good luck!
                I dont agree with this. I have the same problem with my trans to.
                All my seals, clutch, TO bearing are brand new OEM parts right from the dealer. Shit I even got my fluid from the dealer.
                I still have the same noise with only 1000 miles on all the parts.
                From what I have been told, and from searching. The noise seems to be the output shaft bearing (23121224164). This problem is usually caused by the shims wearing out between the bearing and housing cover.
                • kronus
                  • Apr 2008
                  • 13032
                  "Getrag rattle" is what the syndrome is commonly known as. It is thus useful when looking for more information about the subject. On the other hand, complete misdiagnosis like "oh it's the throwout bearing" is not useful.
                  It's like saying "You probably have a broken arm" versus "the weather in France is 12˚ Celsius" when someone comes to you with an injury.
                  cars beep boop
                  • Fidhle007
                    • Oct 2005
                    • 7209
                    99% it's the throwout bearing, sure it could something more mysterious but as a tech, all of the cars I've encountered that have had this issue have been the result of a worn out throwout bearing. This is specifically why I stated to take the car to a BMW SPECIALIST because they will be not only equipped to properly diagnose the noise but also responsible for any work done to fix it.
                    • Spieler209
                      • 120
                      Thanks for all the input... I think when I replace clutch I will just replace everything down below. My neighbor was a bmw mechanic for 20 years and he sais its the bearing. He said they all have a slight wining sound but mine is a little bit on the loud side..yeah more fricken money to spend... I should of just done a frame off restoration at this point... lol Thanks again
                      • wagonizzle
                        • Sep 2006
                        • 443
                        Do yourself a favor and fill the trans with Redline MTL or MT-90 before you spend a ton of money. I think the fiddler makes some valid points, but IMHO you could have getrag rattle and it is a common issue. Seriously, spend the half hour and $25 before you go nuts on the car. Humor me and tell me what happens... if I am wrong, you are only out a few bucks.
                        Originally posted by chileelky
                        amaze about the enthusiasm e30 generate
                        • Fidhle007
                          • Oct 2005
                          • 7209
                          It's a good idea but seriously, it's the the fucking bearing. What have all the techs said so far? The bearing.
                          • Hallen
                            • 1008
                            It could be. But normally you hear the throw out bearing when you have the clutch disengaged (pedal to the floor) and it goes away when you have the clutch engaged. So since he describes something that is the exact opposite of what a throw out bearing normally sounds like, that would lead to the internet diagnosis of the Getrag rattle (since we can't hear it for real).
                            1987 E30 325is
                            1999 E46 323i
                            RIP 1994 E32 740iL
                            oo=[][]=oo
                            • Spieler209
                              • 120
                              All the fluids were changed with Redline from the start.... Fuck it, gonna replace clutch and all bearings down there and seals
                              wonder how much thats all gonna set me back....lol
