I have an 88 325is that I've only had a few weeks. It came with a warm start idle issue that my tinkering has only made worse.
Issue:
When starting the car after it is up to operating temperature it will idle very rough, even dying sometimes. It only does this for about 30 seconds or so before shaping up and idling smooth as it should. It runs great thereafter. The typical scenario is I drive somewhere, run into a store for a bit and come back out and start the car. If I shut the car off and start it again immediately or within a few minutes it does not exhibit the issue. Also from a stone cold start it idles perfect.
What I have done since I got the car:
My focus at this point is the coolant temp sensor. My operating theory is that the car cools enough to fall into the middle temp range on the sensor and it then is giving a bad reading, possibly making the car run rich as if it is cold. Then after the warm coolant gets to flowing the sensor gives a good reading. I have tested resistance per the Bentley but being a noobie with an Ohm meter I am not sure what I'm seeing. The car is up to operating temp and my multimeter reads anywhere from .262 to .267. I can turn the dial on my multimeter to move the decimal point but it doesn't change the value. Looking at the table in the Bentley this may indicate that the coolant temp sensor is testing out good for the high temp range and that my decimal point is off on the multimeter. Or it may not, I don't fully understand what I am seeing. I haven't yet had the chance to test the coolant temp sensor when cold to see what I get then.
Other areas of focus seem to be the idle control valve & the throttle position switch. Neither of which I have tested yet.
Am I on the right track? This issue is getting really annoying! Thanks in advance for your help.
Issue:
- changed oil & filter
- replaced air filter
- replaced spark plugs
- adjusted valves
- run 1.5 bottles fuel injector cleaner through system (other .5 is still in the tank)
- replaced plug wires
- replaced coil
- replaced distributor cap & rotor
- reset ECU/DME by disconnecting negative battery terminal (this actually made the problem significantly worse)
- replaced fuel filter
- adjusted valves (again to doublecheck my work since I am new to E30s)
- cleaned idle control valve
- cleaned throttle body
