So I replaced the starter a couple month ago, and the original one, the top side bolt came loose and then bracket for the bottom broke in half. Now... I replace one and didnt lock tite the bolt... it came loose again... and now I'm in the parking lot...
I'm a moron....
Tags: None
That's actually kind of an odd thing to have happen. You shouldn't need Locktite in there for sure.I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true". -
well I didnt have the crush plates either I dont think. My motor mounts might be bad as well and its causing too much vibration. I dont know... I'm just pissed.Comment
