Changing the Cylinder head
  • Dixon
    • 310
    OK so my friend has a cylinder head for me from a 1986 325es i want to put it on my 1985 325e because the P/O put an i head on it and i want to put it back to stock. I have a few questions about this.
    • How hard is this to do?
    • Is there any thing i should have done to the head before i put it on?
    • Is there anything other than gaskets i should replace when i do it ?
    any input on this will be appreciated
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Make sure to have the replacment head checked out by a reputible machine shop. There is nothing like making your car not run right while trying to "fix" it.
    • Dixon
      • 310
      What will they check on it?
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        They will verify valve sealing with a pressure test (remove the cam before taking it down), and verify the deck, and surface if necessary.
        Your asking kinda scares me.
        • Dixon
          • 310
          Yeah im not very clued up on it at all thats why im trying to learn but not to worry i have my In law helping me and he knows what he is doing, i just wanted to try and figure some things out for myself before we start.
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            No problem then. Also, I suggest if this is your first time, go get a box of ziploc bags, some painters masking tape, and a sharpie. Make note of every connector you disconnect, and bag up and label bolts for specific areas (one bag for Valve Cover, one for cam towers, etc.) , otherwise, it can become a jigsaw puzzle to the novice.
