325i motor using eta ecu and pulleys - water pump issue?
  • Camper Van Someren
    • Sep 2020
    • 31
    Found the reason I had trouble bleeding. The water pump actually didn’t look too bad but the bleed screw was rusted shut. I also replaced the radiator because of all the corrosion in the cooling system. Now it has proper coolant in it to keep this from happening again.
    • tomstin
      • Mar 2015
      • 564
      That would be a problem! YIKES!
      2004 525i Manual - 1985 325E Coupe Manual
