Wiring in 14point7 wideband
  • E30_Beau
    • Mar 2021
    • 25
    I need help with my 14point7 wideband sensor because im not getting a reading on tuner studio with my MSPNP2
    The wiring on the harness side is;
    Blue/ Green (12v power)
    Brown (electrical earth)
    Brown (earth)
    Black (Signal)
    Also i have 2 Brown earth wires and in all the diagrams i have seen i should have a yellow but do not?
    And wideband side
    Red ( power)
    Black ( electrical earth)
    White ( earth)
    Green ( linear output)
    Brown ( simulated narrowband output)
    Blue ( Temp LED)
    Now i have wired it in the following
    BL/GN --- RD
    BR --- BK
    BR --- WT
    BK --- GN
  • Jaxx_
    • Dec 2009
    • 1880
    Have you confirmed you are getting a 0-5V signal on the green linear output?
    If so, have you calibrated your AFR table in tunerstudio?
