Hello, thought if anyone has idea about this, i dont think i need help with automatic(wiring harness, not trans swap) to manual swap but if you want to write about it go ahead, a lot of info on that already but can i just cut my 6 pin tps plug and splice wires into my 3 wire tps and be done with it or does it involve more work ? Engine is m30b35 but harness is from m30b30. I have the original wiring but it has fire/heat damage and thought if i could just swap the wiring. Also do i need to make some wiring or could i just snip the aut. Wires from ecu plug ? As my manual plug doesnt have those or do those go through somewhere else and then come to ecu, im not the best at looking wiring diagrams 😅
Edit: might have actually found my answers by accident 😅
