Clutch Setup
  • HandalE30
    • May 2008
    • 109
    Clutch Setup
    Hello, I need some help, I need to know if there is any difference between the
    m30´s getrag 260/6 slave cylinder, throw out bearing and fork and the
    m20 getrag 250/5 slave cylinder, etc. im having problems with gears not going in smoothly. Thanks alot :D
  • yert315
    • 2734
    m20 slave should work fine with the 260/6 trans. I am using one and it works great.
    Did you buy one new? Try bleeding it?
    • Syncro325is
      • 574
      I read the other thread that you posted in about your problem. I have had similar problems on my M20, have you checked to see if your pressure plate is still intact? Also what clutch setup are you using? My roommates m30e30 is using an e34 m5 clutch.
      • HandalE30
        • May 2008
        • 109
        yup its new... and I bled it too. but thanks now I can eliminate the posibility of the slave being the problem! now the only other doubt is, is the m20 throw out bearing going to work? Thanks alot :)
        • HandalE30
          • May 2008
          • 109
          yes, ive posted everywhere but dont get a clear answer about the part I asked fitting, Im thinking the problem is the pressure plate but it looked fine when I was mounting it, although it was used. im using a (e34) 535i clutch disc and a 535i pressure plate. Thanks. ive been fukd with this problem for a while and didnt want to unmount the whole thing again cause its a PITA! Thanks alot man!!
