ebay m30
Keep in mind those are long blocks, "All accessories such as the alternator, power steering pump and AC compressor, etc, are not included. "
There have been many threads about them, do a search.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
ok i am still new to the M30 motor still learning. i have a buddy doing the swap now and i know another guy here in Texas that has one and i like it a lot.
i am off to do more research this site has helped alot tho.
^ yep, that's a good one.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
would this motor be better?
No, worse. You want one out of an e32/e34 so that it will have correct oil pan already installed, and 3.5 manifold/head AKA "big valve". If you get the one from an e24/e28 you can still make it work though....
Read through the threads.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
wow dude, chill.
you want my honest opinion? I think you should learn how to work on your motor first, then think about doing a swap. Learn the ins and outs, how it works, what sensors do, all that good stuff. Because if you run into any of the problems I did, you will be shit out of luck. Do you know what motor is in your car now? I'm all for another e30m30, I just don't want you to get all the parts, then be in way over your head mid way through the swap.Comment
