where to get a cold thermostat?
  • vic_325
    • 264
    i want to run a 62c thermostat.. i believe the stock temp is 80c? where can i order a cold t-stat from?
  • E30SPDFRK
    • 5716
    BAV auto sells a 71c thermostat. That's the lowest I've heard of.
    Why do you want it to run so cold? You know its not good for the engine right?
    Byron
    Leichtbau
    • yert315
      • 2734
      don't get too cold of a thermostat. The engine is designed to run at a certain temp. Getting a cooler thermostat will not eliminate the need for a cooling fan either.
      • vic_325
        • 264
        so is the 71 too cold still? i knew its not good for the engine but didnt know how cold you can go. Someone told me he was running a 62c maybe its because he's turbo'd or i could have also misunderstood.
        i just dont want to run into overheating problems and i will be running an electric fan.
        • whiltebeitel
          • Apr 2007
          • 2098
          I have a 71* C, it pegs it one tick cooler than the middle. That's as cool as I could want. I bled the air in the system and let it sit in a 90* garage for 40 minutes before it got over half. I sure as hell better not be having any more cooling issues at the track when its triple digits out.
          '89 325i track sloot
          '01 530i daily
          -Enginerd
          • LowR3V'in
            • 4209
            The middle mark for me shows 200f
            Just over the middle is 205/210
            The 1/4 mark is 188/190f.
            Bearly out of the blue is 160f
            So with an 80c thermostat for me it
            leaves it at alittle over the 1/4 mark which
            is about 190f
