My engine was already set to TDC with the timing chain installed....Everything turns over just fine. When I connect the oil pump, something seems to be binding - but the rotor spins just fine by hand - so my chain must be binding? The sprocket does look like it is, perhaps, slightly off kilter - Is there a seal or something I'm missing that would set everything right? RealOEM isn't much help...It seems to me that it has to be the chain or rotor binding - maybe the sideways force pulls the rotor into sealing and I can't turn it dry?
m30b35 oil pan wtf moment
So it was turning OK before you installed the pump, and once you installed the pump it became difficult to rotate?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
