Driveshaft Shop
  • wildstoats
    • Sep 2007
    • 896
    Driveshaft Shop
    Hey guys I'm looking for a shop that can shorten my driveshaft (damn g265!). Does anyone know of any reputable shops in Southeast Michigan or Ohio? I was also wonder what the best method is for measuring the amount that needs cut off. I was going to unbolt the front and rear driveshaft sections bolt the front to the transmission, bolt the rear to the diff, bolt the CSB into place and then measure how much overlap I have between the two parts. Any reason that wouldn't work? I really don't want any more headaches in the driveshaft department so I want to make sure I get this right the first time. Thanks!
  • drift
    • 566
    Which drive-shaft ? If it's the one with small guibo, and the engine mounts on position 3, on '87 or older e30, the front-half of the DS is 2.25 inch too long.
    Had the front of the front-half shortened 2.25 inch. The other ends remain untouched. Fits and runs great.
    http://www.kingofeurope.net/2010/
    • wildstoats
      • Sep 2007
      • 896
      It's a '91 / B34 / G265 / Funk's Mounts and I'm going to attempt to use the driveshaft from my e28. The back half mounts up fine. The CSB from the e28 is even in the correct place to mount up to the e30 the front half just needs shortened a bit and I should be solid.
      • Doughnut
        • Oct 2007
        • 869
        e28 shaft won't work.
        Have your e30 shaft front section shortened and the larger guibo flange welded on.
        ///Monstrosity. (OO≡≡[][]≡≡OO)
        Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
        • wildstoats
          • Sep 2007
          • 896
          Oh? Mind elaborating?
          • wildstoats
            • Sep 2007
            • 896
            Bump. Why won't the e28 driveshaft work? My shell is a '91 318i. I test fitted a large guibo 325e shaft and the CSB doesn't even fit in the tunnel, at least it won't without some "massaging".
            • drift
              • 566
              Picture ?
              • Doughnut
                • Oct 2007
                • 869
                Opps, I apologize for my ignorance.
                I didn't read your post entirely. Yes you can use your e28 shaft, but the front section must be shortened when using the g265. No matter what engine position.
                • wildstoats
                  • Sep 2007
                  • 896
                  Ok, fair enough. I was just wondering there was something I was missing because the whole business seems pretty straight forward. Thanks!
                  • E30SPDFRK
                    • 5713
                    There is a shop right near me that shortened mine for $90. If you can't find anyone near you, feel free to ship it to me and I'll bring it to them for you.
                    I measured mine by bolting on the rear half and holding the front half up up so it is sitting on the guibo. The measurement doesnt have to be perfect because you have like 2 inches to play with with the splines.
                    Byron
                    Leichtbau
