MAF, 19 Lb Injectors ,and E.A.T chip
  • drift
    • 566
    For a stock M30B35 ,
    just wondering if those upgrades ^ are done right,
    How much more torque & hp ?
    Do you have the same upgrade set up?
    Is it worth the time and money ?
    http://www.kingofeurope.net/2010/
  • yert315
    • 2734
    19lb injectors are stock. But a chip will help out greatly
    • drift
      • 566
      Thanks. How about MAF? (retrofit from other OEM brand) Is there any specific size or measurement for B35?
      • yert315
        • 2734
        couldn't tell ya. I don't know if anyone has converted to a MAF setup on their m30 swap..
        • E30SPDFRK
          • 5716
          Miller sells a plug in MAF conversion kit that comes with a chip for only $320.
          +20hp and 23ftlbs
          Byron
          Leichtbau
          • drift
            • 566
            I thought that chip alone gives more than 40 hp? does Miller MAF makes 20 hp and 23 Tq on top of that ^ ? Just want to make sure.
            • E30SPDFRK
              • 5716
              A chip may make 40hp (doubtful), but it would be under the curve. The max power will only go up about 10hp or so.
              The miller system makes that 20hp all over the curve. They have a dyno sheet of it on their site. It wouldn't let me hotlink it or I would have put it up here.
              Byron
              Leichtbau
              • drift
                • 566
                Ok, is it Miller MAF & W.A.R chip combo?
                • wildstoats
                  • Sep 2007
                  • 896
                  There was a pretty lengthy discussion about the WAR chip on mye28 a while back, might be worth reading.
                  http://www.mye28.com/viewtopic.php?t=58971
                  Hope that helps. There are also some discussions on MAF conversions but I can't find them right now.
                  Edit:
                  Found it: http://www.mye28.com/viewtopic.php?t=56888
                  • JMil86
                    • Dec 2008
                    • 558
                    That war chip looks pretty cool, wish I had known about that before I bought my eat chip
                    Nio är livets tal.
