I bought a flywheel from a guy who said it was a
533/M5 17lb flywheel. I am trying to verify what I received is the correct flywheel. I see no part number stamped on it. It is a single mass
flywheel and on the side of the clutch face there are timing marks stamped. I see what appears to be a BMW symbol. I would expect a part number to be in the ring as well bu I see nothing.
It just seems a bit small to me. Here are the dimentions.
Clutch face diameter is 11 1/4", the distand center to center on the bolt holes is 1 1/8" and the center bore is 1 3/4". These are approx numbers.
Just want to make sure I did not end up with the wrong one.
Thanks
kris
Thanks
kris
