flywheel question
  • e30 335i
    • Sep 2009
    • 70
    flywheel question
    hey, i have to replace my clutch soon and was thinkning about getting the flywheel lightend. I have a m30 b34 with a mild cam. Anyone had experience with how they go with the flywheel lightend?
  • RickSloan
    • 2401
    i hear d its great, most go with the 533i or m5 flywheel tho i believe
    Need Illustration or Design work? www.robbiebyerly.com
    • e30 335i
      • Sep 2009
      • 70
      Hey RickSloan, i think i have a late 318i flywheel coz when i went to fit up a 535i e28/e34 clutch the diameter was to big iirc 535i is 245mm and mine is about 215mm in diameter?? which is the same diameter as the 318i flywheel. I never knew what the flywheel was off coz it wasnt labelled at the wreckers it was just in a big pile of flywheels.
      But the main question is how well do they perform lightend vs stock? do u lose any powerband in certain areas? etc etc.
      • Jean
        • 18228
        I am using a 533 single mass flywheel, and it revs up quickly and isn't a hassle to rev match on downshifts. It's still heavy enough for you to let the clutch out and get the car rolling from a dead stop in 1st or 2nd gears. I am with b35/g260/6 and s3.46.
        • BDK
          • Jul 2008
          • 684
          if you go too light they don't want to idle smoothly...
          12-15lbs is about right,
          I know someone who put in an 8Lb'er and hated it....
          stock is 20 something I believe
