m42-b35 wiring. anyone have the pinouts?
  • E30SPDFRK
    • 5716
    Once again, I suck at wiring so if anyone has this already done and written down I would be very grateful. e34 harness.
    Byron
    Leichtbau
  • E30SPDFRK
    • 5716
    Alright after about half an hours searching I found this diagram that has all the 318is c101 pins.
    I know I wrote down the e34 stuff when I did my last swap but I have no idea where it is. If I manage to find it I'll be sure to post it up.
    Byron
    Leichtbau
    • Jean
      • 18228
      Check out one of my wiring threads, I am pretty sure it's in there.
      • E30SPDFRK
        • 5716
        Sweeet thanks Jean! Knew I saw it around here somewhere. I must have been searching with the wrong wordings.
        Byron
        Leichtbau
        • E30SPDFRK
          • 5716
          Upon further inspection, all the pins are the same lol. This is going to be simpler than I thought :)
          Lets hope the e34 harness will plug into the e30 side.
          Byron
          Leichtbau
          • Jean
            • 18228
            Depends on the build date of the e34 it came from....early ones were 20 pin, and later ones were 25 ;)
            • E30SPDFRK
              • 5716
              Yup, I've got the 25 pin lol. Do you know if the pin arrangements are still the same as the 20 pin?
              Byron
              Leichtbau
              • Jean
                • 18228
                This should help - http://www.r3vlimited.com/board/showthread.php?t=146298
                • E30SPDFRK
                  • 5716
                  Gah wiring overload lol.
                  So what I see is:
                  318is 535i
                  hooked to:
                  1 - blue -alternator 25 - blue
                  2 - x
                  3 - x
                  4 - brown/white -ect
                  5 - brown/green -oil pressure switch
                  6 - green/yellow -O2s relay power
                  7 - green -dme power from ignition switch 21 - green
                  8 - white
                  9 - black -engine speed for tach 20 - black
                  10 - x
                  11 - white/blue -SI reset
                  12 - brown -CEL
                  13 - green/violet -fuel pump relay 13 - green/violet
                  14 - black/white -road speed signal 14 - black/white
                  15 - black/green -signal from starter to unloader relays
                  16 - white/black -pin 6 diag.
                  17 - x
                  18 - black/yellow -ignition switch
                  19 - x
                  20 - red/yellow -abs
                  Am I right? I feel I missed a bunch of info in that post but...
                  I think I'm just going to go to a junkyard tomorrow morning and grab me a 20 pin m30 harness. For my skill-set that sounds like the easiest thing to do.
                  Byron
                  Leichtbau
                  • Jean
                    • 18228
                    Since I was in the middle of building a 25pin x20 to 20pin c101 adapter, this should help you:
                    • learningcurve86
                      • May 2008
                      • 715
                      byron loves men
                      Greg
