Oil pressure sender on the e30m30
  • george graves
    • 19998
    Go on...
    Originally posted by Matt-B
    • george graves
      • 19998
      The OE sender is located on the oil filter housing/mounting, not on the head like an M30.
      Hmmm. The s38b36 might have the sensor installed on the filter housing from the factory - I'll check real oem.
      • george graves
        • 19998
        good drawing sowing the location on the head. #13, #14 - M30B34 head:
        e28 M5 oil filter housing: #13 is M12x1.5
        I'm guessing that part is more than $200 - (cause real OEM says $160)
        EDIT: HA! The part is $500 at the dealer. Remind me not to buy a motor sports engine till I win the lottery.
        • george graves
          • 19998
          TRM sells this jobbie - not even sure that would fit.
          • george graves
            • 19998
            parkerperformance has some stuff.
            SW adapter 1/8" NPT to M12x1.5: http://www.parkerperformance.com/sto...hp?item=114854
            • george graves
              • 19998
              • LowR3V'in
                • 4209
                I used something like what TRM is selling for my m20.
                The side would of been good for a pressure sender, but just left it
                blocked off.
                • LowR3V'in
                  • 4209
                  Those bottom mount canister looks messy as hell to change.
                  • TimeMachinE30
                    • Jun 2014
                    • 3749
                    What did you ever decide as your solution?
                    I am eyeing up gauges and their senders as the motor is easy to get to on the hoist.
                    ACS S3 Build / Dinan 5 E34
                    • CorvallisBMW
                      Long Schlong Longhammer
                      • 13039
                      Most aftermarket senders have 2 terminals; 1 for oil pressure and 1 for your factory "idiot light". Just replace the factory sender with the aftermarket sender and wire it up. Done.
                      • LowR3V'in
                        • 4209
                        Does anyone have a really sweet oil pressure, oil temp setup?
                        I want both those things all in the same gauge.
                        • TimeMachinE30
                          • Jun 2014
                          • 3749
                          Right into the block? Or remote?
                          • CorvallisBMW
                            • 13039
                            On m30s it's in the back of the head, against the firewall. You'll need a threaded adapter as the head is M10x1.5 and most senders are 1/8NPT, but that's easy. See build thread in my sig (I put the oil temp gauge there and made a remote mount for the oil pressure, but since the senders are the same you can easily do it the other way around).
                            • TimeMachinE30
                              • Jun 2014
                              • 3749
                              What is the oil's pressure operating range for the M30B35 ?
                              Cannot find definitive specs.
                              • Bearmw
                                • 1323
                                I used a combined VDO sender that looks like the one in George Graves pic and mine is mounted directly to the pressure switch boss by cylinder number six. The sender I used didn't require an adapter and screwed right in and it also can connect directly to the factory low pressure indicator wire for the cluster. I am no longer using the filter mounted senders. I get my oil temp from the oil pan drain plug area ( with the understanding that it might read a bit low). I think the pressure sender I used has M12x1.5 threads and the switch in it triggers at 8.5 psi but I will have to verify that.
                                My pressure is about 55- 60psi at full throttle or at highway speeds and can drop to about 15 or so at idle when hot. I have never had the oil pressure light come on or flicker even at idle when hot with synthetic 15/50.
                                The pressure sender I ended up using is VDO 360-007 and it was around $40.
