Well I just picked up a B35 head from a guy on the E28 forums, I know should for done more research before hand.... but it was a impulse buy. Are there anythings to watch out for when mixing it with a B34 bottom end? It will drop my C/R a little, but one can always add a few more psi to make up for that. Pistons will be replaced down the road. Is there anyone running this?
B34 Bottom End with B35 Head
3 second search from mye28:
Originally posted by Big Bronze RimOriginally posted by StreiffyDoes any e34 head constitute as a B35 head swap? Meaning, do I need to find a e34 535i head over finding a 525i head for maximum performance gains?
With which ever head it is, does this swap turn my b34 into a b35 motor? Theoretically? What are the differences?
Upon choosing to go this swap route what all b35 parts do I need to install as well? Intake manifold, wiring, intake all together, throttle body, ecu, etc?
Also, I'm interested in millerperformance's MAF conver w/ WAR chip. Now with the swap do I need to install an e34 ecu with miller's e34 WAR chip/MAF conversion? Or, does all this stay e28 stock and I look into ordering the the package for my e28 ecu/intake?
I'm looking to build up an entire b35 and put it in down the road. If all this b35 head swap looks to price'y, I should save the $$ for the build up hunh? But I want some good power in the mean time.
Now, if I decide forego the swap and stay with the b34 head and the mechanic has the valve cover off. What could I do to get a little more boost outta her? I heard I can just throw a b35/e34 Cam in there. Is that true? What other b35 parts need be installed? Is there an adjustable cam gear out there to match up to? Will that statisfy my mild hunger for now?
