NO SPARK m30 swap!!!!
  • kylelauffer
    • Dec 2009
    • 624
    1991 e30 1989 m30 engine and harness
    i got fuel in my car now! The only thing is no frickin spark! I put a test light on the coil on the side that goes to the computer. It gives me power when key is on. When cranking it gives me signal.
    Im getting pulsating power at the coil and the injectors.
    I do not get pulsating power at the crank shaft position sensor or the number 6 spark plug. But i do get power to the cps and number six spark plug.
    I took the coil plug and put to metal to ground it to see if any power to the distributor and there is no ark! Or any sparks. And i do get fuel!
    I swaped cps
    swaped relays
  • yert315
    • 2734
    you need to stop making new threads for the same questions.
    did you replace the cap/rotor when you did the swap?
    • george graves
      • 20003
      You never answered the questions in the other thread. No answered questions = no help.
      Originally posted by Matt-B
      • weaksauce
        • Apr 2009
        • 550
        you should make another thread about it. the 3 on the first page are not nearly enough.
        • kylelauffer
          • Dec 2009
          • 624
          I gave all info on this thread so its updated. What does it take for a helpful response.
          • george graves
            • 20003
            No - you didn't.
            We are a peaty helpful bunch here - very helpful, especially in the m30 swap section. The guys that have done it know that finding all the answers can be a bit of work, so we pull together and lend a hand when we can.
            Here's how your conservation looks to us;
            you; HELP ME!
            us: ok - well, we need to know X
            you: HELP ME NOW!
            us: :???:
            Hopefully someone will come along with the patients needed to help a person like yourself figure out the swap. That guy ain't me.
            Good luck with your swap.
            gg
            • kylelauffer
              • Dec 2009
              • 624
              okay besides arguing how about you try to awnser the question? ohhh cuz you dont know it...
              • george graves
                • 20003
                Oh man...I don't even know what to say.
                (walks away)
                • Mde36
                  • 509
                  I suggest you use the search function since you just told off one of if not the most helpful person on the forum.
                  Powered By Ford
                  • LowR3V'in
                    • 4209
                    So from your first post your injectors are
                    firing, your coil is firing, your spark plugs are also firing.
                    You're getting spark and fuel. But you say later on your coil isn't firing?
                    How were you getting spark to #6 then?
                    Make sure your spark wires are in the correct location.
                    Sounds dumb but does happen.
                    • weaksauce
                      • Apr 2009
                      • 550
                      I swaped cps
                      swaped relays
                      try a different coil
                      i'm having a hard time following what you are typing try this format:
                      spark-yes
                      fuel pressure-yes
                      timing verified-yes
                      etc
                      just because the injector is getting power does not mean it is not stuck closed. if the engine sat for a while it could be a problem.
                      Also the fuel pressure regulator could be causing problems
                      • kylelauffer
                        • Dec 2009
                        • 624
                        ohh jeez! okay im getting fuel. the injectors are pulsating. i have power to the coil. but the computer it telling the coil not to make power to the distributer. the computer is holding back for some reason. when everything is hooked up correctly. but thank you for the people that tried to help me out i really do apritiate =)
                        • weaksauce
                          • Apr 2009
                          • 550
                          spark-yes
                          fuel pressure-yes
                          timing verified-yes
                          etc
                          so fuel-check
                          spark-no
                          fuel pressure-who knows?
                          if the computer is telling it not to spark, how can it be pulsing the injectors?
                          • kylelauffer
                            • Dec 2009
                            • 624
                            it is pulsating injectors. fuel is all working! power to the coil! one side of coil is power while cranking and the other side is pulsating power. the way it should be correct? but no power to the distributor? computer is not grounding a wire or not letting power from coil to go to distributor?
                            the next thing i am going to try is what i read on a earlier thread. was to go to my round wirering plug. and number 15 wire to ground it to frame. and on the e30 chassis fuse box female connectors to switch number three to position number 8 on the plug. and see if i will get spark then.
                            • kylelauffer
                              • Dec 2009
                              • 624
                              is everybody stumped just like me??
