my temp guage works now. but my car over heats if i put the radiator cap on it overheats. and with it off it stays in middle temp but is constantly boiling over the overflow tank. any ideas?
overflow tank boiling over??
sure there isn't an obstruction in the radiator? If you're positive it has been bled completely and a new pressure cap is on, I'd start questioning the radiator itself. Might be worth taking to a radiator shop and having them check it. OR Flush it with water and see if you can force water through it with one of those prestone kits. Thankfully thermostat's are built to fail in the open position, but if you've never changed it, time to replace with a lower temp one.
The most common cause of the symptoms cited is air in the cooling system. If proper bleeding has been done with no relief, there's a good possibility that the cause of the air in the cooling system is from a leaking head gasket.
A simple check for that is to fully bleed the cooling system, drive the car for a bit (but don't let it overheat), and re-bleed. Release of more than a few bubbles then, or on a subsequent bleed, is evidence of a leaking head gasket.
FYI: the best way to bleed the cooling system is with a vacuum bleed/fill system.The car makes it possible, but the driver makes it happen.
Coolant under pressure boils at a higher temperature than when non pressurized. So when it's open it's boiling at what altitude your at Lower it like when you start going higher into the atmosphere aka less pressure it boils faster.
Your blood will boil if you are exposed to the atmosphere at 68K feet.
While on discussion of properly bleed system where is your bleeder screw? For E36's I fill it then drive up on a set of wooden rampsget it warm and open the bleeder and then fill it some more and do this till it over flows.
Then back of and let cool down and check levels, if over filled I use a turkey baster to suck excess out of reservoir.
so earlier in the posts a guy posted a proper way to bleed a e28 535i. i took off the hose that goes from radiator to coolant resovoir. added another hose to the coolant resivoir. i put cap on the resivoir. blew a air hose threw the coolant resivoir hose in to the coolant tank to follow through to the radiator and held the hose coming off the radiator (the little one that goes to the overflow to begin with) hold it straight up in the air and watch for bubbles with water come out. put hose back to coolant resivoir. add water and try to hold tank as high as possible. and before this whole process i poured water in the coolant resivoir until it came out of the bleeder screw. without the engine on.
now this all worked for me. and i learned from this site. thanks everyone! im having fun with it now! http://www.mye28.com/viewtopic.php?t=58368
Originally posted by kylelauffer View Postso earlier in the posts a guy posted a proper way to bleed a e28 535i. i took off the hose that goes from radiator to coolant resovoir. added another hose to the coolant resivoir. i put cap on the resivoir. blew a air hose threw the coolant resivoir hose in to the coolant tank to follow through to the radiator and held the hose coming off the radiator (the little one that goes to the overflow to begin with) hold it straight up in the air and watch for bubbles with water come out. put hose back to coolant resivoir. add water and try to hold tank as high as possible. and before this whole process i poured water in the coolant resivoir until it came out of the bleeder screw. without the engine on.
now this all worked for me. and i learned from this site. thanks everyone! im having fun with it now! http://www.mye28.com/viewtopic.php?t=58368Originally posted by kylelauffer View Posti have bled it countless times.
