Going M30 from M42
  • PFCRayB
    • Nov 2009
    • 403
    Going M30 from M42
    im picking up a b35 motor soon and wanted to know about the wiring issuses that i might incounter, it is going to be my DD so it is not going to be a crazy build just chip cam and exhust. aslo what trany should i use, the stock m42 one(i still need to do the m20 clutch and flywheel swap). and i did search and it really didnet help http://www.r3vlimited.com/board/showthread.php?t=155411 is what i found...
    thanks
    PFCRayb
    Originally posted by Erick
    Dude the M30 is stupid simple design. It's 6 manly men inside the block pushing up and down on the cylinder with Hercules-like force.
  • E30SPDFRK
    • 5707
    If you can find a harness from an 89 535i you will be able to plug it right in, no modifications necessary. You will need a transmission from an m30, the m42 one won't bolt up.
    Byron
    Leichtbau
    • PFCRayB
      • Nov 2009
      • 403
      what about a m20 trans?
      • Good & Tight
        • Apr 2004
        • 2057
        M20 tranny will not bolt up either.
        Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
        ____________________________
        E-mail Panayiotisx2@gmail.com
        Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
        • MikeDE
          • 1873
          M10 trans or any tarns that had originally come attached to an M30.
          -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
          • PFCRayB
            • Nov 2009
            • 403
            so the extra 5speed trans i was going to put on my 02 before i sold it will work?
            • Sputnik
              • Jan 2010
              • 808
              no the guys an idiot an m10 tranny won't work
              • PFCRayB
                • Nov 2009
                • 403
                so i still have to find a trans then damn......
                • yert315
                  • 2734
                  don't spew nonsense if you don't know what you're talking about, please.
                  There have been a couple people who have run m10 transmissions with their m30 swap. The majority of people go with the m30 trans because it's beefier and will be able to hold the stress of the engine better.
                  • PFCRayB
                    • Nov 2009
                    • 403
                    What is the m30 trans to use
                    • Erick
                      Official R3V Drifter
                      • 11169
                      The e28 M30, due to the same shift linkage as most e30s
                      ..::Support FullOpp::..
                      FullOpp Stickers for sale!
                      Feedback Thread
                      • lashtx
                        • 133
                        I am in the process of aquiring all the parts to do the M30 into a '91 318i with the M42. Get the 89 e34 harness that way it mates right up to the c101. I am using the 260/6 tranny out of an E28 535i. 325e front drive shaft and 318i rear.
                        Got my intake and valve cover back from the powder coaters. They look sweet. Can't wait to get this thing in. Recently bought and e39 540i and have been driving that, drove the e30 318 yesterday for the first time in three weeks. It was sad, no power. Just a little bit more.
                        • PFCRayB
                          • Nov 2009
                          • 403
                          lashtx do you have a build thread and thanks for the info that helps a lot
                          • Jean
                            • 18228
                            5speed from e24/e28 m30 cars, or from e34 535i cars (i don't remember if e32 735i cars came with 5speed or not, would work as well), is the way to go. although m10 g240 from the early 318i cars will bolt up as well but not sure how long it will last though...
                            • lashtx
                              • 133
                              No build thread yet just a garage full of parts! And no fundage. But all my parts are pretty! Hahahha as soon as I start I will do one. Needs to be soon could not get my 318i into gear this morning, almost had to drive my ford!!!
