m30 understeer
    m30 understeer
    does an m30 give understeering probelms to an e30 chasis
    well i would presume it would add a bit of weight. im not sure how much. but i do know my M50 which is 70 lbs more then the m20 didn't really change to much of the weight distro. however my M50 is on adjustable mounts and is quite close to the firewall. either way it shouldnt be an issue as you can cure the understeer by generating some oversteer :)
    Live Fast. Drive Faster.
    "Nitrous is like a hot girl with an STD... :)
    You wanna hit it, but your afraid of the consequences :(
      gotcha ;)
        yeah. M30 swaps are amazing.
          S50 > M30 :shifty
          1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing Pads
            m30 is actually lighter then the s5x motors i believe and is no heavier then the m5x
            so the same as any swap. but you have torque all the time ;)
            Need Illustration or Design work? www.robbiebyerly.com
