Bearings for m30b35
  • dani_e21
    • 7
    Bearings for m30b35
    heloo!!
    I started to reconditioned my engine (m30b35),and I hit to a problem with the bearings.I don't know what bearings to choose red or blue.
    The crankshaft have blue points and engine block have red points.
    Original bearings have part number for both colors.
    What bearings must buy?
    e30 335it
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    Check out www.realoem to get the part number you need.
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • dani_e21
      • 7
      i know part number for any color but i don't know what color to buy.
      e30 335it
      • Jean
        • 18228
        If the bottom end is in good condition (or you can measure it), you probably just need Standard size bearings. I ordered mine from autohausaz they were 11211261033 STD main
        • dani_e21
          • 7
          Thanks but I prefer original bearings .
          I hope to find what color cu buy
          How to choose the color for bearings?
          e30 335it
          • Jean
            • 18228
            Lol....why are you set on COLOR when it's more important to get the right SIZE.
            Look at realeom and you'll understand they come in different sizes. RED and BLUE come in different sizes, so you must order the correct SIZE.
            http://www.realoem.com/bmw/showparts...74&hg=11&fg=20
            • dani_e21
              • 7
              red and blue have the same size.
              any repairs are the same size.
              look carefully:)
              e30 335it
              • Jean
                • 18228
                02 GUIDE-BEARING SHELL RED 60,00MM 2 11211261033 $27.36
                02 GUIDE-BEARING SHELL BLUE 60,00MM 2 11211261034 $27.36
                02 GUIDE-BEARING SHELL RED 59,75MM(+0,25) 2 11211261035 $37.98
                02 GUIDE-BEARING SHELL BLUE 59,75MM(+0,25) 2 11211261036 $33.48
                02 GUIDE-BEARING SHELL RED 59,50MM(+0,50) 2 11211261037 $37.98
                02 GUIDE-BEARING SHELL BLUE 59,50MM(+0,50) 2 11211261038 $37.98
                02 GUIDE-BEARING SHELL RED 59,25MM(+0,75) 2 11211261039 $28.47
                02 GUIDE-BEARING SHELL BLUE 59,25MM(+0,75) 2 11211261040 $28.47
                03 Bearing shell, red 60,00MM ? 11211261041 $13.78
                03 Bearing shell, blue 60,00MM ? 11211261042 $13.78
                03 Bearing shell, red 59,75MM(+0,25) ? 11211261043 $15.98
                03 Bearing shell, blue 59,75MM(+0,25) ? 11211261044 $12.16
                03 Bearing shell, red 59,50MM(+0,50) ? 11211261045 $15.98
                03 Bearing shell, blue 59,50MM(+0,50) ? 11211261046 $21.31
                03 Bearing shell, red 59,25MM(+0,75) ? 11211261047 $15.98
                03 Bearing shell, blue 59,25MM(+0,75) ? 11211261048 $20.09
                04 Bearing shell, blue 48,00MM(0) 6 11241284551 $10.85
                04 Bearing shell, blue 47,75MM(+0,25) 6 11241284553 $13.27
                04 Bearing shell, blue 47,50MM(+0,50) 6 11241284555 $13.27
                04 Bearing shell, blue 47,25MM(+0,75) 6 11241284557 $10.94
                05 Bearing shell, red 48,00MM(0) 6 11241284550 $10.85
                05 Bearing shell, red 47,75MM(+0,25) 6 11241284552 $13.27
                05 Bearing shell, red 47,50MM(+0,50) 6 11241284554 $13.27
                05 Bearing shell, red 47,25MM(+0,75) 6 11241284556 $13.27
                • dani_e21
                  • 7
                  look at what we broke
                  the same size and red and blue
                  crankshaft is 1 share (+0.25), but what color ?
                  the crankshaft have blue point and engine block red point
                  e30 335it
                  • lennon
                    • Jun 2008
                    • 1416
                    explaining the colors is so complicated. normally the reds give a tighter clearance, for example: 60mm red bearing shell might be 59.98, where as the 60mm blue might be 59.97. you really need to measure and check the clearances to know what shells you should be using.
                    edit: but 0.01mm isn't a huge thing anyway. i wouldnt worry too hard about the colors, just make sure your clearances are good.
                    • dani_e21
                      • 7
                      for connecting rod bearings must be one blue and one red?
                      e30 335it
                      • lennon
                        • Jun 2008
                        • 1416
                        the same thing applies for the rod bearings as the main bearings. are yours marked red and blue on the rods also?
                        • Lurker27
                          • 821
                          FWIW I went with standard rod bearings/main bearings and new rod bolts for my bottom end rebuild - rings and bores were fine at 300k and compression was full. Crank showed no wear. Bearings showed low oil wear likely caused by shattered plastic in oil pump pickup. Engine turns over easily and has adequate oil pressure at idle.
                          '89 335is +turbo
                          • dani_e21
                            • 7
                            the crankshaft is marked with blue dand the rods with red
                            in some articles say that put red and one blue .
                            I am confused:(.
                            has anyone a manual where to write exactly how to make?
                            sorry to bother you but do not know what to do.
                            e30 335it
                            • Jean
                              • 18228
                              Dani? (I assume that's your name), it's not rocket science really. Stop going by colors, what matters most is that you get the right size bearings. I don't understand how you are not seeing that a red or blue can be of many different sizes....
