Alright, so i have a stock 1990 325i and I want to swap in a bigger motor. I have a 1989 735iL and a 1992 325i non-vanos. I wanted your guys' opinion on what would be a better for a daily driver and maybe a little bit of autox. I know the m30 would be faster but I heard that they have cooling issues. So my question is, what would be the better swap reliability wise?
m30b35 vs. m50b25
Newer motor, newer internals. It's gonna be more reliable. And from what I've heard, I think that the m50 is a little easier of a swap. I just put in a m50tu into my e30 and it was pretty straight forward. Just do a lot of research. So if I was you, do the m50. -
The m50 stock may not have as much power as a m30 but the room for improvment is far greater as a DD now if you want to turbo your swap at some point and build rediculous power I would do the m30, but I have to say I love opening my hood at car events or little meets and having a croud gather trying to figure out why my motor looks so new"God created turbo lag to give V8's a chance" Taylor D.
since were talking about engines, does any one know the weight difference from a m52b28 iron block vs aluminum?1991 e30 328i M52 swapped: Gone
1995 e34 540i/6 1 of 76 Clean
1985 e28 euro 525i the dailyComment
As far as more fabrication, the m30 can use the stock harness. If you don't use the stock harness you can use a 20 pin e34 harness, which will plug straight into your e30. Motor mounts would have to be fabricated but they are readily available. m30 swap will also use your stock trans crossmember, stock exhaust if you want, etc.- '88 m54 coupe
<3Comment
Do you think a m30 would be cheaper to rebuild because they both need head gasketsOriginally posted by audiquattrotbimmers b4 b*tches....remember that.
2000 Audi S4 B5 Laser Red
1990 Nissan 240sx - Drift Missile
2006 CBR600RR
m30b35 > m50 NV
m50 vanos or Obd1 M52, both with m3 cams and tune > m30b35Check out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
