E30 S38 dry sump kit
    Hi Guys,
    So I finally got my e30 S38 to run, I've done one trackday with it at the car is great :-)
    You can see this video, it was made just after the engine strarted running, I didn't had all the wires connected (the wire from the speedometer to the ECU was disconnected)
    It's just a small video, I'll try and make a decente one :-)
    but because the engine had to go down a bit, now I have e problem with my ride height regarding the oil pan.
    So I have 2 questions for you:
    1. Do you now any online store that sells dry sump kits for my car? (and price )
    2. Do you now any online store that sells wider and shorter oil pans (if the dry sump is too expensive ou doesn't exist for my car)
    thanks
    G
    got to search from an e26 M1, the M88 of those years worked with dry sump.
    e30 325i 1988 track toy
    e30 M3 1989 M106 motronic swap (in process)
    e36 M3 1995 S50B30 turbo
    e38 750il M73N
    Toyota Tundra 2UZFE (workshop car)
    BMV Motorsports Guatemala
      VAC sells one.
      Why do you want to go dry sump?
      Sacramento, CA. ----------- Like us on Facebook!
        Originally posted by jibbajabba View Post
        VAC sells one.
        Originally posted by grehur View Post
        Hi Guys,
        thanks
        G
        i wouldn't mind a dry sump just for the cool factor
          You should check out hardparking.org.
          paint sucks
            Looking at costs, I would prefer a wider oil pan.... increasing ground clearence.
              Hey, i know you from e30.pt! Como e que vai esse s38?
              Originally posted by kendogg
              Don't know, but the E90 wasn't designed from the ground-up intending to be a racecar like the E30 was.
              OG RACECAR
