Air conditioning + m30 swap
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    Originally this thread started as a "shit, there's no way I can get A/C working in my m30 swap", but after some more hammering/swearing/parts it turns out, you totally can! For those running mounts built by Otis (Good & Tight) you should have plenty of room for the compressor to clear your radiator. You'll have to do some slight modifications to your m30 compressor bracket, but it's very simple. If your A/C is working when you start your swap, don't undo the lines! Leave it all sealed, you'll be able to do the entire motor swap and then bolt the compressor right up :)
    pictures of compressor bracket mods on page 2 of this thread, post #24: http://www.r3vlimited.com/board/show...=169097&page=2
    Make sure you have your cooling system rigged up to handle the extra load though:
  • chadthestampede
    • Jul 2008
    • 3600
    god damnit
    Originally posted by LJ851
    Feedback
    • Jean
      • 18228
      What's the part number on your compressor? I put mine next to the bracket and it looked like it would clear with less than 1/4 of room between it and the radiator hmmm. I'll try mounting in next weekend...
      • george graves
        • 19992
        sub'ed - need to know this.
        Originally posted by Matt-B
        • Good & Tight
          • Apr 2004
          • 2057
          My mounts clear the compressor in position II. Living in south florida you have to have a/c if it's your DD.
          Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
          ____________________________
          E-mail Panayiotisx2@gmail.com
          Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
          • CorvallisBMW
            • 13039
            I'll take a look later today when i get home. It's a very late compressor since my car is a '92.
            • lashtx
              • 133
              Mounts
              Well that's good to know, so with position 2 do you need to massage the firewall?
              Thanks
              kris
              • Good & Tight
                • Apr 2004
                • 2057
                Thanks
                kris
                Very little massaging is needed right were the back of the head is.
                • CorvallisBMW
                  • 13039
                  With the clearence I have behind the head, And your mounts clearing with a bit of massaging, my guess is the compressor will fit on your setup.
                  Come to think of it, I could just switch my motor mounts. But beating the firewall would involve removing the whole engine/trans again, something I do not want to do.
                  • Good & Tight
                    • Apr 2004
                    • 2057
                    You could use a pry bar if needed while engines in place, no need to remove the engine.
                    • ky325es
                      • 175
                      so if i massage the firewall a little and use your mounts i be able to have a/c
                      here in ky hottest it gets is about 90 and it cools down during the afternoonn
                      • CorvallisBMW
                        • 13039
                        I would have to remove the insulation from around the bellhousing too, no way the engine will scoot back even another mm with it in place. If I can get access to a lift to drop the subframe, I will seriously consider it.
                        • Heysüß
                          • 911
                          i'm planning on sucking it up and just doing the damn thing without a/c.
                          did it last year in an s10 in the sc summer. hahaha
                          09/1989 325i 4 Door
                          +M30 Swap
                          +Z3 Steering Rack
                          • lashtx
                            • 133
                            RAD!! It gets hot in Texas as well got to have AC!
                            Anyone know if the M42 compressor can be adapted to work with the M30?
                            Kris
                            • george graves
                              • 19992
                              ^good questions - what compressor fit on what brackets?
