Hello all,
This is my first post here, but I have been following this forum and in particular the M30 swap forum for some time now. I've learned a lot about what is involved with the M30 swap, but I have a few questions.
Here is what I have:
-M30 B34 with the B35 oil pan/pump w/ necessary wiring/ecu
-Lots of e28 parts from my 535i that was totaled
-A complete Euro 635csi parts car with highlights being M90, dogleg transmission and I think 3.07 LSD
Here are my goals:
-Initially I want to have a daily driver NA setup with stock ECU that I can take to autocross every now and then.
-Eventually I want to megasquirt this engine.
-Finally I would like to turbo this motor using megasquirt to give me somewhere in the 350hp range.
Here are my questions:
1. Should I use the M30 or the M90 for this? It seems like from what I've read the M90 would make the better NA car if that was my only goal. Does anyone have experience adding a turbo to this motor? I should mention that the person I bought the 635csi from mentioned it had a cam upgrade, although I'm not sure which degree it is, the receipts only mentioned schrick cams.
2. I plan on rebuilding which ever motor makes sense. Price is a concern with me, I really have no clue how much more it would cost to do the M90 over M30. More than likely I would stick to basics like rings/bearings for bottom end and whatever might be need for head. Is the M90 harder to find the necessary parts to rebuild on a reasonable budget?
3. With the 2 motors I have is there some kind of mix matching I can do between them? I ask because I saw a few old threads about using the M90 to do a stroker motor and it interested me. Once again I don't have a budget that would allow for much else in the internal parts other than what is necessary for a basic rebuild.
4. Finally, as much as I'd love to keep the close ratio dogleg transmission for this car, it just doesn't make sense considering I will be doing some degree of daily driving with it and I could not stand the 1:1 5th gear at highway speeds. Which transmission would be a better choice the one from a e28 or e34.
Thanks for reading my long winded post. Of the BMW forums I frequent this one seems to have the most knowledgeable members in regards to this swap. I hope posting here will help me find the answers to my questions. I'm sure this won't be the last time I have a bunch of questions like this.
Thanks in advance,
Eric
Here are my goals:
Thanks in advance,
Eric
