this engine:
The S50B32 was an evolution version of the S50B30. Power of the 3.2 L version is 316 hp (236 kW). Improvements over the previous 3.0l version include Dual Stage Vanos for the exhaust camshaft, increased compression ratio to 11.3:1, reduced valve stem thickness (and weight), and higher redline. This engine has a bore of 86.4 mm and a stroke of 91.0 mm giving a displacement of 3201 cc. It has a maximum permissible speed of 7600 +/-50 rpm, and a permissible constant speed of 7400 rpm. Power output was rated at 316 hp (DIN) @ 7400 rpm, with a torque rating of 258 ft-lbs (DIN) @ 3250 rpm.
Applications:
know of a good engine dealer overseas? or what the price comparison would be to a stateside s50/52?
Applications:
- 1996-1999 E36 M3 (except for the U.S.)
- 1997-2000 M Roadster (except for the U.S.)
- 1998-2000 M Coupe (except for the U.S.)
