Yet Another m30 No Start Thread
  • chadthestampede
    • Jul 2008
    • 3601
    Got my engine in and wired up properly, finally, but it's not cranking at all. I seem to be having this same problem:
    I get power to everything on the interior, all windows, lights and sunroof work. ICV runs when key in the 'on' position. Fuel pump does not run unless the relay is jumped, I've tried several relays I have lying around.
    Pretty much sounds like the same problem Jb325is was having.
    Any details on jumping the obc relay? It's under the drivers side kick panel, isn't it?
    The only difference I have is that I had it wired with my old swap harness, turned it on for a few seconds and the entire harness started smoking. I figured it was better to swap the harness than to try and figure out where the bad ground was. Though now I'm wondering if something might have burnt out internally.
    Originally posted by LJ851
    Feedback
  • chadthestampede
    • Jul 2008
    • 3601
    well i jumped the obc relay, to no avail. I jumped the gr to the gr/rd wire on the plug that plugs into the relay and nothing changed. Im going to try and find my multimeter to do some testing.
    Feedback
    • wildstoats
      • Sep 2007
      • 896
      Is your starter engaging at all? Also is it a b34 or b35?
      • chadthestampede
        • Jul 2008
        • 3601
        starter is clicking but no crank. It's a b32 converted to b35 electronics (m1.3)
        Feedback
        • chadthestampede
          • Jul 2008
          • 3601
          im getting power to the starter, both ignition coil terminals, one pin on.the fuel pump relay, 2 on the main relay, etc. I even tested the battery. Everything seems right but no crank.
          Feedback
            If the starter clicks the problem will be:
            High resistance in the solenoid lead, main power lead, or ground path
            Bad starter.
            Monitor the voltage at the solenoid lead while trying to crank the engine. It should not drop. Likewise for the main power lead. From the starter body you should see less than a volt to chassis ground.
            • chadthestampede
              • Jul 2008
              • 3601
              i tried it with an m20 starter i had lying around... No dice. Im getting constant 12v at the main starter lead while cranking, but seemingly none at the solenoid lead...is there something thats supposed to be hooked up to that directly?
              the body gives off a varying voltage from below 1 to 12 or so.
              Feedback
