parts list for m30 swap.
  • screamingbmwe30
    • Jan 2005
    • 415
    anyone have a parts list for the e30 m30 swap? anyone on this board done it yet? thanks!
  • george graves
    • 20003
    Not a compleat list but here it goes - there are other options, but this is what I used. You can save some money by doing it as ely did (user name rs4pro3)
    e24 auto m30 motor 90k
    Getrag 265 tranny out of a e30 m3.
    e30 m3 driveshaft (shortened and rebalanced)
    Shortened shift linkage
    m20 rubber motor mounts
    e30 m3 tranny crossmember.
    e24/e28 ecu
    89' m20 wireing harness (custom spliced)
    e34 m30 oil pan
    e34 oil pump (rebuilt)
    e34 m30 airbox
    custom motor mount brackets
    e30 m3 tranny mounts
    e30 m3 flex disk
    e28 radiator
    e28/e24 radiator hoses (and some m20 hoses)
    Lots of cussing and swearing(not optional)
    note. If you can find the right e30 driveshaft combo you don't have to pay for a expensive e30m3 shaft or have it shortened. (ask ely)
    In compairson the m50 BOLTS RIGHT UP. M30 swaps are not easy.
    or you can go to e30.de http://www.e30.de/335i/00.htm they have a wright up there too....
    Originally posted by Matt-B
    • screamingbmwe30
      • Jan 2005
      • 415
      what kind of hp/tq do m30s make?
      • Bryson
        • 1490
        George, I take it that you've personally done an m50 swap as well. Otherwise, that's quite the bold statement you've made there about bolting right in.
        I'm not disagreeing, rather just making sure you've got it straight on what's involved
        I'd like to check your car out some time, I'm in SLO about an hour and a half from SB
        I'd like to do the swap myself some day, just because I'm curious about it, but I'm turned off by the weight and lack of advantages of an m30 over an m20. After all, there are still 12 valves, an AFM and a distributor :P
        • screamingbmwe30
          • Jan 2005
          • 415
          but 220 hp 8) stock
          anyone know the weight of an m30 vs. m20?
          • Addissimo
            • Mar 2004
            • 1820
            http://www.bimmerforums.com/engine_faq/
            look for yourself
            edit: 220 crank hp can be obtained pretty easily with an m50 (m3 cams, 24lb injectors and custom software)
            Doing something M50 related? -> http://www.addissimo.com
            On Myspace? ->http://groups.myspace.com/r3vlimited
            BF2142 SN = BillyGoose
            • DEV0 E30
              • Oct 2004
              • 8893
              Originally posted by screamingbmwe30
              but 220 hp 8) stock
              That looks like only the 3.5 liter stock has around 220.
              M30 -- Straight 6 cylinder SOHC 12V. Big Six.
              1973-1993.
              143kg 315lbs
              Used in E12 525/528, E28 525i, E23 725i, 2800CS, E28 528i, E23 728i, 3.0CS/i/L, 3.0Si, E12 530i, E23 730i, 3.3Li, 633, 732i, 733i, 535i, 635i, 735i, E12 M535
              2.5i (150bhp), 2.8i (184bhp), 3.0 (185-208bhp), 3.3 (200-206bhp), 3.5 (218bhp)
              edit:::
              Just realized this isn't the thread for this.
              • george graves
                • 20003
                Ok, maby a bit of a overstatment. But not by much. What's the partlist for a m50 swap?
                M50
                e21 brake booster(modified)
                Bend heater hoses.
                e34 m50 oil pan
                ummmm....
                That's about it right?
                Lot less details to work with. Yes, I worked with M3 Ryan to do the swap. We made custom one-off motor mounts. If you can get ahold of the mounts from e30.de it would be a lot easier.
                Since we were starting from scrach, We had to figure out things like motor placement. Try positioning a 300 lbs of oddly shpared motor into a tight space and keep it there well you fab up motor mounts is not a easy task. And no, you can't just hang it off a hoist. And it has to be DEAD on.
                No, I've never done a m50 swap...so I guess I talking from only forum knoweldge.
                Love to have you down some time Bryson. I want to check out your suspention set up.
                The m30 motor is COMPLEATLY different than a m50. Different feel, different Hp and T curves.
                All the old bimmer guys refer to a m30 and BMW's Legandary smooth inline 6. It's feel like a big m20.
                The m50 is a totally differnt beast. If I had my way I would have gone with a s38. Now there is a motor! But the cost was too high for me,
                What I am trying to say is you can't pick a motor based on weight, HP/ T numbers. M30? M50? they are apples and oranges.
                • Bryson
                  • 1490
                  mmm s38
                  I'm all about non-vanos 24 valve sixes :P
                  • JPbmw
                    • 466
                    look for yourself
                    put that money into the m30 and you'd still have more then the m50 ;)
                    '86 325
                    • Bryson
                      • 1490
                      that all depends how cheap you get m50 parts ;)
                      hm, free m50 plus a few hundred in mods.... you'll be over 220 likely
                      • bmw335ist
                        • Apr 2004
                        • 100
                        Car is a 1988 325is with a motor swap. I am running a 1987 535is motor and 5 speed tyranny.
                        MOTOR- 3.5L big six stock power is 185hp and 201tq (US spec) motor mounts are custom made.
                        ELECTRONICS- I retained stock computer from the 3.5L and stock ABS computer from the 325is
                        TRANSMENTION- Getrag 265
                        DRIVE LINE- custom length was done in Portland at a driveline shop.
                        DIFFRENTIAL- I am running a 3:25LSD currently so far it is good for 150+ mph
                        Here are the current specifications of the motor.
                        -big bore throttle body
                        -Extrude honed and bored intake manifold
                        -Metric Mechanic turbo spec head
                        *bench flowed 18% over stock
                        *port and polish
                        *surface turbulence groves on the back side of valves
                        *surface turbulence in the cylinder chamber
                        *292 lifted cam
                        *Double valve springs
                        *new rocker arms
                        *Double oil sprayer
                        -ARP head studs
                        -S38 head gasket
                        -8:0:1 compression pistons
                        -stock bore & stroke
                        -E34 oil pump and pan
                        -11.5 lb aluminum fly wheel
                        -6 puck w/ springs clutch disk
                        -M5 pressure plate
                        Here are the specifications of the turbo kit.
                        -T61 turbo
                        -log style exhaust manifold
                        -large waste gate (fully adjustable)
                        -Turbo and manifold ceramic coated
                        -Large air/water inner cooler
                        -water hoses, reservoir and pump
                        -RRFPR fully adjustable
                        -42 lb injectors
                        -Custom TCD computer chip
                        -Stock engine management.
                        • JPbmw
                          • 466
                          Sweet, what rwhp #s are you making ?
                          why use the s38 head gasket over the m30 one?
                          '86 325
                          • rs4pro3
                            • 5808
                            Grand total for my swap was $3000 G-tech meter said 150 hp at the rear wheels.
                            Here is my list(shortened version)
                            84 633csi blcok
                            87 535i head
                            735i intake
                            535i exhuast manifolds
                            86 up 535i downpipes
                            E34 oil pan, pump, level sender,
                            E34 alternator/power steering brackets
                            E34 alternator
                            E28 535i ac compressor bracket
                            e30 AC compressor
                            E30 power steering pump
                            E32 140 amp Alternator
                            E28 535i radiator
                            mixture of e30/e28 radiator hoses
                            E34 starter
                            E24 12 lb flywheel and new clutch
                            Getrag 260/6 tranny
                            e36 guibo(same as E28/E24/E23 one)
                            87 325e 5-speed driveshaft(no shortening)
                            e30 m20 rubber motor mounts
                            e30 m20 tranny mounts(need a few spacers under neath)
                            E30 reverse light wiring harness
                            m-coupe shift lever
                            e30.de type 1 motor mount arms.
                            e30 tranny crossmember
                            Here is a full parts list of everything I purchased for the engine
                            E34 Oil pan 40.00
                            E28 535i cylinder head 32.87
                            E28 535i 5 speed Radiator 30.07
                            E28 535i Valve cover 5.58
                            E28 535i AFM and Airbox 8.36
                            E23 Intake manifold 13.93
                            E23 Throttle body 0.00
                            E24 84 633csi engine (170k miles) 300.00
                            E24 633csi 5 speed tranny 0.00
                            E34 Oil pump 90.00
                            E34 Power steering brackets 0.00
                            E28 Thermostat housing 0.00
                            E24 ECU(008) 40.00
                            E24 ICM 0.00
                            E24 ICV 30.00
                            E32 Alternator(7k miles) 74.00
                            E24 Lower gasket set 35.00
                            BMA parts 120.00
                            Pelican parts 70.00
                            Head Work 116.00
                            Steve Haygood parts 105.00
                            Clutch kit 61.00
                            Valve seals 6.03
                            Parts from dealer ship 10.52
                            Oil Pan Bolts 6.31
                            Surface flywheel 30.00
                            water pump pulley and intake 30.00
                            AC Bracket 25.00
                            bolts from Dealership 34.53
                            Fuel line/vacuum lines 14.18
                            IX Washer fluid tank 20.00
                            Alternator Belt 14.99
                            Bolts from Dealership 10.30
                            Power steering pulley 10.00
                            Power steering Belt 10.99
                            Fuel line, Pivot Pin 14.46
                            B25 Coolant lines 15.00
                            Brass Fitting 3.00
                            Tranny bolts 6.54
                            e30.de type 1 mounts 234.13
                            shift linkage 20.00
                            E28 Down pipe 0.00
                            O2 sensor Bung 14.94
                            B35 Starter 35.00
                            Brake vacuum line 10.00
                            Brass fittings(vacume) 6.00
                            exhaust bolts/fuel lines 19.36
                            Rubber Engine mounts 37.95
                            Guibo 24.90
                            BMA parts 51.52
                            shifter parts/driveshaft bolts 127.44
                            Exhaust Flange 8.00
                            Tranny Crossmember 25.00
                            e32 Oil Cooler block 75.00
                            Electric Fan 100.00
                            Electric Fan wiring 20.00
                            Main Relay 12.56
                            Fuel Injector Service 80.90
                            87 325e driveshaft 90.00
                            cataylitic converter 53.36
                            B35 ECU/Wiring Harness 75.00
                            2nd Cataylitic 53.36
                            Intake boot/center support 51.77
                            o2 bung welding 10.00
                            cold air intake 45.00
                            Thermostat cover/Bolts 81.10
                            Exhuast Fab 140.00
                            Right now I'm working on conerting the engine managament to motronic 1.3 from a 92 735i and have probally $400-$500 into parts alone for that.
                            85 325e 2.7 ITB'd stroker
                            • rs4pro3
                              • 5808
                              Pictures of the engine here
