driveshaft for b34 swaq
  • BMWBradford
    • 19
    ok so im using Matti,s engine mounts and i need a driveshaft for a b34 into a e30 . what year M3 driveshaft works ?? i dont want to have to cut and blah blah blah i just want a direct fit . so . i need a big guibo driveshaft that works for my swap please help me out .
  • Massive Lee
    • Sep 2006
    • 6785
    Any reason for not wanting to cut a driveshaft to the proper length?
    massivebrakes.com
    • BMWBradford
      • 19
      i dont have a driveshaft specialty shop close to where i live thus im ordering from a far just to get the front section anyway . so id rather not have to buy send and pay double the price you know ? unless i could get my small guibo driveshaft cut down and have a big guibo end put on ?
      • Massive Lee
        • Sep 2006
        • 6785
        It's a tough one. You may want to fit your guibo onto the tranny, and then carefully measure the total distance between guibo and diff flange. You can't use an e36 driveshaft are the front-rear length is totally different from an e30 unit. Once you have the total measure that you need, then I can measure what length is my spare e30 M3 driveshaft and let you know if it works. If it doesn't then you have NO choice than cut, weld and rebalance your own driveshaft.
        And you need to send out th front and rear parts of the driveshaft so that the shop can balance it. Or have somebody with nearby driveshaft shop shorten a driveshaft, mark it then split it before shipping. Then youreassemble with the matching marks.
        massivebrakes.com
        • kronus
          • Apr 2008
          • 13032
          A large-guibo ETA driveshaft will work just fine unless you're using the Getrag 265 (the one with the removable bellhousing), which is ~3 inches longer than the e28 Getrag 260.
          ETAs came with large guibos in '87.
          cars beep boop
          • Massive Lee
            • Sep 2006
            • 6785
            e30 M3 driveshaft is 60-7/8" long FYI
            massivebrakes.com
            • Doughnut
              • Oct 2007
              • 869
              This is what I did. Had the front half shortened and a large flange put on.
              Cake.
              ///Monstrosity. (OO≡≡[][]≡≡OO)
              Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
              • Sharino
                • Jun 2005
                • 186
                When getting a driveshaft shortened, how percise do you need to be when measuring it? To the closest 1/8 inch or more/less?
                www.eurowinnipeg.com
                www.E30S38.com
                E30 Mtec2-S38 | V10 TDI treg | E34 M5 | E39 M5 | Corrado turbo VR6
                • Operator62
                  • Jul 2005
                  • 119
                  I have a shortened driveshaft for sale. I paid 600 bucks for it to be done. BMW driveshafts can't just be welded back together. They are fused. I would like to get 300 for it, but I can go lower. I honestly don't know what the length of it is, but I can find out for you. I am using an e28 trans(also for sale) and the engine is back far enough that I had "massage" the firewall for it to fit.
                  • Massive Lee
                    • Sep 2006
                    • 6785
                    Wow. "Fusing" is expensive in Tenessee. I had a driveshaft shortened and balanced locally for $125.00
                    massivebrakes.com
                    • Operator62
                      • Jul 2005
                      • 119
                      It wasn't done in Tennessee. It was shipped to California. There are no local places here in Tennessee that could do it. It wasn't just shortened and balanced. They rebuilt the whole thing. And they are fused. It is a form of welding, but not like most driveshaft shops do. It's not some guy with a 7018 running a bead with the shaft turning on a lathe. It's done with some expensive machines that turns one piece while the other is stationary, and they are brought close until they touch and once they reach a "plastic" state they are forced together.
                      • LowR3V'in
                        • 4209
                        Expensive!
                        It would be cheaper buying a new aftermarket shaft with rebuildable/greasable u-joints and then have THAT shorted.
                        • e30_kid89
                          • Apr 2006
                          • 489
                          With a G260/6 WITH THE THINNER OUTPUT flange and funkmasta's mounts I used a front half e28 535i 5spd driveshaft with the rear of a late model 325i driveshaft...Got em balanced together and it fits perfectly, no need to shorten! the key is the flange however.
                          • bataangpinoy
                            • Jul 2008
                            • 1636
                            here's a trick.
                            if you have an m20 G260, take its output flange and transfer it to the M30 G260 to use your oem smaller guibo driveshaft.
                            My feedback:
                            http://www.r3vlimited.com/board/showthread.php?t=186328
                            http://e30tech.com/forum/showthread.php?t=74911
                            Instagram:
                            @gears_n_glory
                            @functionmotorsports
