e28 528i manual swap fit e30?
  • payney8
    • Jun 2007
    • 899
    As above. I found an e28 getting parted. The owner believes the gearbox is a getrag 260. Im just wondering whether it will all swap over or its an e30 to e30 only swap.
  • yert315
    • 2734
    Does your car have an m30?
    • payney8
      • Jun 2007
      • 899
      no so obviously the flywheel/ clutch will not fit. Im talking gearbox bellhousing, clutch master/slave cylinders, pedal box. Drive shaft. Is any of that able to fit?
      • LowR3V'in
        • 4209
        m30 and m20 have a different bell housings. Will not work. :(
        Clutch slave will work though.
        My guess is non of the other stuff will fit either. imo
        Never read about anyone putting in a e28 pedal assembly.
        • bataangpinoy
          • Jul 2008
          • 1636
          you dont even need the e30 pedal assembly, just the longer bolt and the metal arm that goes over the clutch slave from the manual car
          My feedback:
          http://www.r3vlimited.com/board/showthread.php?t=186328
          http://e30tech.com/forum/showthread.php?t=74911
          Instagram:
          @gears_n_glory
          @functionmotorsports
