M30 info need it
  • matias88e30
    • Dec 2009
    • 1110
    M30 info need it
    is there any difference between m30's engines?
    like the e30 'i' 'e' engines?
    i will get that write up on friday when i get some cash..
    thanks for any advice!
    no more boosted m20, 91 318i...
  • slammin.e28
    שמע ישראל
    • 12054
    Yes and no. There are a lot of M30 combos.
    2.5 L (2494 cc/152 in³)
    2.8 L (2788 cc/170 in³)
    3.0 L (2986 cc/182 in³)
    3.2 L (3210 cc/195 in³)
    3.4 L (3430 cc/209 in³)
    For a quickie overview:
    • matias88e30
      • Dec 2009
      • 1110
      THANKS BRO!... Good info! so im assuming most of guys will do the 3.5 swap?
      • slammin.e28
        שמע ישראל
        • 12054
        It's the most readily available. M30B35 is the best M30 swap. M30B34 is good for turbos. Basically, if the engine isn't really cheap, or free, get a B35. It's a whole lot easier to wire and produces more power. I did a M30B35 swap into my e28, which came with a M30B34.
        • wannaBMthree
          • Apr 2007
          • 601
          how do you tell if you have a B35? my m30 came out of an 88' e? and the intake says 3.5...
          • slammin.e28
            שמע ישראל
            • 12054
            Originally posted by wannaBMthree
            how do you tell if you have a B35? my m30 came out of an 88' e28 and the intake says 3.5...
            B35s have the valve cover that says "BMW" toward the front. B34s have a roundel almost under the AFM, next to the oil fill. B35s say =3.5= on the intake manifold with a roundel on top of the mani. B34s say 3.2/3.5 on the mani and =BMW= on top.
            B35:
            B34:
            That's the easy way.
            To dig deeper, b34s (unless it's a euro high comp b34) will have a dished piston. The H/C Euro engine has "piano-top" H/C pistons. They look like the top of a grand piano on top. The B35 pistons are higher comp than B34, so they have a ridge built up w/valve reliefs. Combustion chamber is different, as is the cam. B35 intake valves are 1mm bigger than the B34. Oil pan is different too. B35 had the oil sump closer to the front of the engine. B34s have it a little further back. Exhaust manifolds are bigger on the B35 too. Not the oil filter housing on the B34 block vs. the B35. B34, the filter is removed in a downward direction, B35 it's taken out of the top.
            B34s also ran with a hydro-boost brake system, therefore, there is no vacuum hose from the intake mani to the brake booster. Most B35's ran with a vacuum booster, and will have a hose from the back of the intake mani to the brake booster. B35 also has fewer vacuum hoses. I counted 2 on mine. The B34 (see pic above) has quite a few more. Also the B35 fuel injectors are covered in a plastic goojah. B34 injectors are out in the open.
            (Throw a B35 head on a B34 block for a nasty low compression turbo motor.)
            Generally, if it's out of an e28/e24, its a B34. Late (1988+) e24s got the B35, as did the e34, e32. There is no high compression, Euro B35. They are all 9:1.
            My B35 has a VIN on the valve cover too. It came from a 91 e34.
            That's just all off the top of my head for now.
            • matias88e30
              • Dec 2009
              • 1110
              Nice Thanks!
              i would love to do a m30 swap in a future! thanks for ansering the questions!
              • slammin.e28
                שמע ישראל
                • 12054
                Yeah dude. Def try to go M30B35. I swapped my M30B34 in my e28 for a B35. There is a reason! Lol! GL!
                • matias88e30
                  • Dec 2009
                  • 1110
                  if uncle sam arrives i might get a e28 for dirt cheap.. running and stickshift.. not sure if it is m30b35 but w.e.. i might go take a look at it with cash in hand.. would love to have a m30 e30 dd! and some mooooooddss lol... thanks for the help buddy!
                  • Doughnut
                    • Oct 2007
                    • 869
                    If it's in an e28, it's a m30b34... Just get a b35 oil pan and pick up, you can use the gearbox though.
                    Rare to get a manual e28, grab it for sure.
                    ///Monstrosity. (OO≡≡[][]≡≡OO)
                    Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
                    • matias88e30
                      • Dec 2009
                      • 1110
                      ill see what can i do, i want to finish my turbo e30, but i will not forgive myself not buying that e28.. thanks for the tip tho!... so a m30b35 will be a 535is right?
                      • LowR3V'in
                        • 4209
                        B35s don't come in e28s.
                        Just the eta/b34s. :(
                        • george graves
                          • 20003
                          Then there's the euro L-block. And the turbo version m90.
                          Originally posted by Matt-B
                          • Doughnut
                            • Oct 2007
                            • 869
                            e34 535i's yeah... Not e28 535i's.
                            • dannyyisntt
                              • 3141
                              And 1988-1989 E24's, 1988-1992 E32's.
