My m30 only gets up near half way on the temp gauge when I'm siting in traffic, Most the time it stays at just over the quarter mark.  Ideas?  Often when it does finally warm up it starts to creep over the halfway mark, put upon getting some airflow (getting up to speed) it goes back down.  Strange I tell you, where should I start?   Thx
					M30 running cold
	Tags: None
 Yea its a newer b35 so you could be right. No thermostat? Strange. I didn't do the swap a buddy did, I'll have to look into it. Thanks.Comment
 Someone correct me if I'm wrong on this, but....stock b35 thermostat temp is 78C. The temp gauge in your cluster is designed for an m20 which is 88C, so even if the thermostat is operating properly it will always seem a bit cold. It should read just above the 1/4 mark.Comment
 You need to use E30 sensor to match the cluster....it will read the temp as it did with m20 ..Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
 OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
 for the dme, you use the "matching" one from e24/e28/e32/e34...but for the cluster it needs to be one from e30... Same as when people do 24v swaps, the m/s5x one from the e34/e36 chassis isn't going to work with e30 cluster ;)Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
 M30 running cold
									M30 running cold
