The car has been down for what seems likes months. Its almost done but, I don't have the time. I need to sell it for a running car. I'm open to trades on reliable daily drivers.
I don't have any pictures but, they will become available if anyone is seriously interested.
IF YOU HAVE MONEY and want ALL the pictures and info, email me(address below). I have receipts for almost everything. I will deliver within 100mi of Atlanta, GA.
$6000
The bottom line: Finish the wiring, fab exhaust, install new starter, tune MegaSquirt ECU, fill with coolant. All the parts are there and it will be bad ass.
Title in hand. Clean, black 1989 coupe with new 16x7 gold LM reps with new tires. H&R/Bilstien Sports, THR CAB, strut braces F+R, B&M short shifter, Momo Champion Wheel. Stop tech x-drilled rotor, Hawk hps pads, SS braided lines.
The Motor:
Keep in mind this is a brand new build! No corners were cut!
m30b34 w/ Shrick 284 and g260/6
all new gasket/seals
new Head Bolts
new timing chain, guide rails, tensioner
new b35 CPS and trigger wheel (Motronic v1.3)
new crank bearings and piston rings
new Bosch Starter
new water pump and thermostat
new Bosch Dist. cap, rotor, wires, plugs
new IE Silicone water hoses
new Sachs M5 clutch set, TOB, 533i flywheel resurfaced
new guibo, CSB
input/output seals in trans
AKG motor/trans mounts
3.73 open and 3.25LSD
Custom Intake piping w/ silicone couplers
2.5" MagnaFlow SS Muffler and piping
e28 Radiator
Flex-lite aux. Fan
DIYAUTOTUNE PnP MeagSquirt ECU
Plenty more I can't remember. It is of the utmost quality...
$6000
The Motor:
new Head Bolts
new Bosch Starter
new guibo, CSB
e28 Radiator
Flex-lite aux. Fan
