m30b34 question
  • kman_e30
    • May 2007
    • 573
    m30b34 question
    I'm trying to get an idea of what my car will feel like power wise with a b34 in. Basically compared to other some other in the same weight/power category. E36 325 328, mk3 vr6, s13 sr20, etc..... Kinda of a dumb question
    84 318i drift car
    04 mk4 gti 1.8t
    96 e320
    63 plymouth valiant
  • RickSloan
    • 2401
    have you driven all of those?
    its a low slow revving monster. it pulls hard whenever you want it. Its not the fastest thing in the world but when you hit it it feels like you could pull a freight train...
    Need Illustration or Design work? www.robbiebyerly.com
    • ttrousdell
      • Nov 2009
      • 1770
      That's why you get the M5 flywheel and yes it pulls!!!
      The Build:
      • LowR3V'in
        • 4209
        If you can get your hands on a b35 that will be a huge upgrade right there vs b34
        and plus it'll have the right oil setup and block off plate in the back so you can just slide it in.
        • kman_e30
          • May 2007
          • 573
          I driven all the cars i listed, I'm just trying to get an idea of what to expect. I'm using a b34 because I crashed my old drift car, an 85 635csi and I have all the stuff to do the swap besides the motor mounts and a few other things
          84 318i drift car
          04 mk4 gti 1.8t
          96 e320
          63 plymouth valiant
          • kman_e30
            • May 2007
            • 573
            Also is a 4.10 diff too high for an m30 b34 swap? And where can I get some good engine mounts from?
            84 318i drift car
            04 mk4 gti 1.8t
            96 e320
            63 plymouth valiant
            • RickSloan
              • 2401
              so you have driven a b34 635?
              its a lot like that just lighter and much more nimble. it pulls harder cause its lighter. i dont really know how else to explain it...
              • RickSloan
                • 2401
                talk to otis (good&tight) for the mounts and a 4.10 is to much. a 3.25 or 3.73 will be best.
                2.93 does 80 in second and 115 in 3rd ;)
                • LJ851
                  • 7919
                  Otis only does B35 mounts.
                  Qbang makes B34 mounts.
                  OP, just imagine 3 medium build adults getting out of your 6 and that will be close. I would not do a 4.10 cause B34 strength is broad torque band. That being said , gear will depend of how you intend to use it.
                  Lorin
                  The M30 is God's engine.
                  • kman_e30
                    • May 2007
                    • 573
                    the car its going into is my new drift car, so im not worried about top speed or cruising rpms. i want to be able to spin as much of 3rd as possible(for 3rd gear drift entries), in my e24 with the 4.10 i could only spin 3rd for a short while then i would have to drop to second. im going to assume that i could do this no problem with an m30 and a 4.10 in an e30
                    thanks for the heads up on the engine mounts
                    84 318i drift car
                    04 mk4 gti 1.8t
                    96 e320
                    63 plymouth valiant
                    • LJ851
                      • 7919
                      ^ You are correct, E30 M30 should be much more tail happy than E24 M30.
                      Lorin
