my oddball GMW
nice man good to see some one do some thing different for a change
keep up the good work motor is gonna be beastComment
been busy lately with little things. drivetrain pulled out and on stands. degreased transmission and wire wheeled the entire casing, except the shifter which i have a new one for. i decided while the engine was out to clean/shave brackets in the engine bay. used undercoating to spray "frame" portion down and the front of the trans tunnel. painted the bay semi-flat black rattle can 4 coats. turned out decent for the theme of the car which ill give away when i get to it. i also decided to start powder coating things myself instead of a buddy, so i hit up craigslist...bam $50 working oven, and $60 for my buddies old hot spot eastwood powder coater. i used matte black on the engine mounts and transmission mount, turned out great. Another swap going on as well..i picked up a steering rack for a 95 m3 from a local european salvage yard. turns out the rack is zf remanufactured with new tie rod ends for only $80! more good things to come!
some new things done. engine parts are cleaned up and powdercoated. built the alternator bracket, used a turn buckle for the tensioner. decided to delete powersteering all together. picked up some awesome powder for powder coating. now that the engine is all together (almost) its ready to go back into the engine bay.
Hell yeah. This is such a sweet and unique swap! I like this idea, and it seems that you have the vast majority of things figures out. Nice progress.1984 318i
sr20det swappedComment
Colour scheme looks very 'Detroit diesel.' Not my thing, but it looks as though things are coming together nicely, cant wait to see it in the bay.///Monstrosity. (OO≡≡[][]≡≡OO)
Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
been pretty busy lately, get the powertrain assembled, clutch all figured out and in. engine is put back in finally.. started tackling some preliminary harness routing in, and decided to tuck the wiring harness. decided to sell my hx40 to a good buddy and go to the holset hx52, which is what i wanted to go with ultimately. rebuilt the turbo, sandblasted the housings and eventually will be powercoated. Another swap going on is rx7 brake upgrade. I got some power-slot rotors for a corrado (had a buddy machine the hubs), picked up caliper brackets, and reman calipers along with hp pads.
as for power goals anywhere from 500-600, depending on boost and how big my balls are feeling that day haaa.Comment
some new things going, got the top end of the engine assembled, new custom cometic headgaskets, german engineering coilovers fitted, strut housings sandblasted and powder coated installed, brakes all clearanced (still need a spacer and wheel stud converision). i was really doubting if the wheels would even clear the rx7 brakes, but they do. i really wanted to set the car on the ground just to see how it sat, and its perfect for me, wheels are 205/55/15, coilovers almost all the way down, and it looks good. more stuff coming!!!
wow, awesome project!!! ruined bmw ftw!Comment
