how much is a b34 setup worth?
  • kman_e30
    • May 2007
    • 573
    trying to get a feel for how much i can sell my setup for?
    m30b34 (did a compresstion test each cylinder was at 150)
    trans
    ecu
    harness
    635 drive shaft
    basically new radiator
    basically almost all the stuff needed to do a b34 swap
    84 318i drift car
    04 mk4 gti 1.8t
    96 e320
    63 plymouth valiant
  • bmw335isturbo
    • Mar 2006
    • 218
    Why selling? You giving up on 335i swap?
    1986 335is-1988 335ist -1991 335istsigpic
    • kman_e30
      • May 2007
      • 573
      not entirely, just checking out options
      84 318i drift car
      04 mk4 gti 1.8t
      96 e320
      63 plymouth valiant
      • Lurker27
        • 821
        $500, sorry these motors are essentially worthless
        '89 335is +turbo
        • Jean
          • 18228
          B34 stuff isn't very much in demand so maybe $400, now the trans would probably sell for 200-300 if it's in good condition/not noisy/problematic.
          keep in mind, for e30 use the oil pan/sump needs to be out of e32/e34 b35 cars. b34 isn't worth much because it's not the best M30 engine to fit in the e30, it doesn't flow as good as b35 and doesn't make as much power and isn't "AS READY" for a swap as B35 out of e32/e34 535i/735i cars.
          b34 wiring/dme is worthless, $100 tops for all of it.
          rad maybe $75, new e28 535i rad isn't expensive.
          driveshaft- no idea, as usually e30 driveshaft is used for the swap.
