m30 engine i wanna swap, need info
  • 00ronburgandy00
    • Jun 2005
    • 107
    Hey i was wondering if this is good, i know a guy on e28 forums who might sell me his extra motor he has. I want to do this swap but im kinda scared of the costum work. I talked to a guy in austrailia who said that the fire wall had to be modified and the tranny tunnel did too. Am i just being paranoid or will this be easier than im tryin gto make it out to be. Also i was wondering on my 91 318 is will i have to run some kind of stand alone or will the fuel lines/ pump/ work with this, going from the 4 to the 6. I will welcome the help greatly.
    Thanks.
    whats that its spikin 26 and holdin 16
  • rs4pro3
    • 5808
    Fire wall pounding is recommended for the best balance. Do you know how to swing a hammer? Then your set. Your fuel pump, lines, etc.. will work fine with the M30.
    85 325e 2.7 ITB'd stroker
    • 00ronburgandy00
      • Jun 2005
      • 107
      awsome so its easier than it sounds
      • rs4pro3
        • 5808
        To some extent, you still have to use the E34/E32 oil pan and pump, custom coolant hoses, wire it all up, etc......
