M30 afm...
  • george graves
    • 19998
    M30 afm...
    Hi George,
    I'm way down in New Zealand & have been checking out your posts about your E30 & electronics you make. I am a fan of the M30 engine & your E30 set up looks good, you may be interested in knowing that i removed the AFM on my M30 535is & went Map-ecu 2 piggyback,you keep the existing motronic & use the Map-ecu system to adjust timing & AF ratio etc.I gained a massive 18hp & tons of instant torque that really shows how good the M30 is.Check out the Map-ecu if interested,my brother is the designer in New Zealand.In place of the AFM i just put a black aluminium pipe so looks really good.
    Map-ecu 2 piggy back? Anyone with more info?
    Originally posted by Matt-B
  • B83M533W
    • 99
    Maybe he is talking about the miller MAF swap?
    1983 533i - in the middle of a m30b35 swap
    1986 528e - the DD
    1992 325i Vert
    • walinsky
      • 16
      Maybe these guys...
