M30 understeer
  • wannaBMthree
    • Apr 2007
    • 601
    M30 understeer
    New z3 rack helped a ton. Wondering what other modifications could improve my handling response up front? Sways?
    Currently on IE3's with Bilstein's. Tower brace in front, camber kit in rear.
  • KenC
    King of Kegstands
    • 14396
    Sways.
    Originally posted by Gruelius
    • LJ851
      • 7919
      Negative camber in the front.
      Lorin
      The M30 is God's engine.
      • Balleristic31
        • Aug 2009
        • 4198
        This
        It will change your life
        -NICK
        • wannaBMthree
          • Apr 2007
          • 601
          Yea I need to sell my UUC plates (Never Installed) and get some adjustable CG ones.
          Originally posted by KenC
          Sways.
          22/19 or 25/22 ?
          • LJ851
            • 7919
            With IE 3s you should be fine with 22/19
            Lorin
            • Grand525
              • 491
              http://www.tcmotorsports.net/blog/in...car-in-action/
              • EThirty318i
                • Dec 2010
                • 219
                M3 offset CAB's would help wouldn't they?
                • wannaBMthree
                  • Apr 2007
                  • 601
                  Cool PIR to boot.
                  On high speed turns, I do have those installed as well.
                  • george graves
                    • 20003
                    I doubt that it's the m30 causing the problem.
                    Originally posted by Matt-B
                    • LowR3V'in
                      • 4209
                      Get Convertible front and M3 rear sway.
                      Ultra cheap, but a HUGE improvement.
                      I have 50lbs+ more of crap you don't up front. There is no understeer.
                      • Wh33lhop
                        • 11705
                        And I doubt the Z3 rack fixed it.
                        22/19 or 25/22 ?
                        GCs are decent but if I were you I'd go for Vorshlags. They have real sealed bearings so there is no need to lubrify them every few months (I have GCs).
                        paint sucks
                        • bmw335isturbo
                          • Mar 2006
                          • 218
                          Originally posted by lj851
                          negative camber in the front.
                          +1
                          1986 335is-1988 335ist -1991 335istsigpic
                          • Holland
                            • Nov 2008
                            • 7212
                            Lop 2 cylinders off.
                            Originally posted by DEV0 E30
                            • VinniE30
                              • 2113
                              Just FYI - this has nothing to do with having an M30.
                              They weigh the same as the 24v e36 engines.
                              Zinno '89 <24v swap in progress>
