I opend up the bottom of the M30 that I am rebuilding and I was nicely surprised. In the bottom of the oil pan is a busted up piece of plastic. It looks like it was part of the timing chain guide. It is chopped into tiny pieces of plastic. What all is on the bottom side of that engine and is made of plastic? I have a pic of the parts but you can not tell much from it. It seems to be mostly a straight ribbed piece of plastic but it has rounded corner pieces too. I wonder if the original owner dropped something down in there and just left it or if something broke and was eaten alive by the engine. Anyone know what it is? The pic is at http://www.nodusinc.net/temp/100_0744.JPG
Also on a side note I got the gasket for the oilpan and it is cork. What?? I have only heard bad things about cork gaskets never sealing and always leaking. What do you M30 guys out there use or do you have any problems on your engines?
