Pondering on m30 swap. I have some questions.
  • slammin.e28
    שמע ישראל
    • 12054
    B34 if your turboing, only if your turboing.
    B35 if you want N/A, or you can go turbo in the future.
    B34 w/B35 head for uber low compression for turbo.
    Take teh valve cover off whatever engine you look at and make sure the cam oiler banjo bolts haven't backed out. That's a problem they had, but some loctite fixes them. I check mine each time I do a valve adjustment though, just in case.
    I swapped a B35 into my B34 e28. It's a fucking blast to drive. I can just imagine a B35 in an e30.
    • Grand525
      • 491
      "While you are there" parts would raise your budget quite a lot.
      • mbonanni
        • Sep 2011
        • 6236
        I will hopefully be buying Jean's m30b35 when he pulls it for his v8 swap.
        He said I will need to do the rear portion of the exhaust, driveshaft, and shift arm I think I don't remember.
        I will be trying to find a cheap 1987/8 four door shell or cheap running one to start putting some bucks into to get it ready.
        For the exhaust (which I do not know much about) what would be a good setup for a quiet one. I tend to stay out late and a loud car is the last thing I want when I come home at 1 a.m. Maybe something that is quiet down low but throaty up top. idk I will have time to figure it out.
        • Bearmw
          • 1323
          An easy exhaust would be b35 manifolds and down pipes connected to the rest of a b25 setup or you could run the b35 down pipes into a y-pipe with single outlet 2 1/2" to tailpipe. If you make a custom exhaust use a good resonator and a good larger rear muffler to keep it quiet.
          • mbonanni
            • Sep 2011
            • 6236
            Okay cool. I'll have to look into that more, or find someone to do an exhaust for me.
            • mbonanni
              • Sep 2011
              • 6236
              So everyone correct me if I am wrong.
              Only the 1987/8 early model e30's have the big quibo driveshaft.
              The early model e30 is also harder to wire compared to any 1989-1991 e30.
              I really want An early model four door, but I am scared of very technical wiring because I wouldn't want to start a fire. How much harder is it really?
              • slammin.e28
                שמע ישראל
                • 12054
                1987 is perfect for wiring. It has the proper ECU connection, and the fuel injector harness isn't in a plastic box, like the 1988+ cars. 1988+ will work though, just needs some finagling with the injector harness.
                • mbonanni
                  • Sep 2011
                  • 6236
                  Sweet. Well I will do my best to find an 87. I wanted an early model anyways.
