how do i know which ecu do i have
  • streetknight
    • Oct 2005
    • 236
    i have a 1987 325 m20b27 engine. how do i know which ecu i have and where is it located? reason i ask is because i want to megasquirt it and the earlier motronic ecu has 2 sensors on the fly and the later 1.3 has only 1. which ecu is it?
  • rs4pro3
    • 5808
    2 sensors on the flywheel, more then likely your ecu ends in the part number 021
    85 325e 2.7 ITB'd stroker
    • streetknight
      • Oct 2005
      • 236
      • Jordan
        • 12913
        above the glovebox, below the dashboard.
        passenger side of car
        https://mtechniqueabs.com/
        • James Crivellone
          Head Janitor
          • 6305
          86 and 87 had 027 ECU's, which allowed you to remove and install a chip (IE not soldered on)
          • rs4pro3
            • 5808
            ya 027 removable chip
            007 can't remeber if you can remove the chip in them or not
            then 021 has the soldered in chip
