535i-same head
Newer 535i or 735i, direct bolt on, but you loose compression but gain larger valves and a higher duration cam. I'd bolt on an E28 535i or e23 735i head on but port it and install a performance cam.
I was told you can you can use the E34/2 bottom end with the older E28 head but i'd guess you might run into valve to piston clearance issues using the E28 bottom end with the E34/2 head due to the valve cut outs in the pistons being to small for the larger valves ?
