Car: 1986 325e Sedan. Since it's over 25yrs old, no emissions required!
I've been collecting parts for 6 months now... I'm hoping to start the swap in 2 weeks or so now that the summer heat isn't in full blast. This is my first engine swap of any sort. Hopefully it'll be a good learning experience.
This is what I have so far:
M30B34 engine complete from a 86 635csi
M30B35 oil pan and oil pick up from a 89 735i
oil pan gasket
260/6 manual getrag transmission from a 86 535i
Complete harness (no cuts at all) from 86 535i
ECU from 86 535i
e28 radiator from 88 535is (from an automatic...)
e28 front half drive shaft (just in case even though I have a 86 325e)
complete e28 535i exhaust
325ix washer fluid bottle
89 325i coolant resovoir
QBANG b34 motor mounts
E36 Z3 3.15 Torsen Differential
E30 325e motor mount and transmission mount bushings.
New Water pump
New Thermostat
Valve cover gasket
new accessory belts
e28 lower radiator hose
e32 upper radiator hose.
"T" from e28 upper radiator hose for
New Sachs clutch kit with throw out bearing and pressure plate
Standard Flywheel from 535i E28
7k RPM instrument cluster from 89 325i
Things to buy:
Sanden 508 A/C compressor (R134a refill)
Sanden compressor mount (or just fabricate my own)
New rear main seal
Considering:
I'm considering the Z3 2.7 steering rack. Problem is that I just haven't found one yet. I'm considering just settling for an easily attainable e36 rack. Or even not doing one at all...
I found a decent deal on e36 M3 front spindle / brake setup for the 5 lug swap. I want it for the bigger brakes but that means I'd need new wheels and tires (just got new tires for the e30 last month!). So this is also in the air. If I go with the 5-lug swap, I'll need a 318ti or Z3 trailing arms and wheels of course.
I'm also considering doing the walbro 255 fuel pump swap. The car is old so ideally I'd like it swapped out for peace of mind.
What I have not planned for:
I have no idea what I'm going to do for the exhaust! I'm thinking of hacking up the e28 downpipes and have it welded one way or another on to my existing 325e muffler... I haven't given it too much thought yet.
I'll post pictures of the progress! Let me know if you guys have suggestions or point out things I haven't considered.
Thanks
oil pan gasket
ECU from 86 535i
New Water pump
New Thermostat
Valve cover gasket
new accessory belts
Things to buy:
New rear main seal
Considering:
Thanks
