O-k, considering how many people have overheating issues I will probably get flamed for this, but here goes. I finally got my SPAL 1600 CFM pusher and 80* tstat installed. I wired up the relay to a 85/80 temp switch mounted in the tstat housing and got the fan installed nice and close to the radiator. I also made two openings in the front bumper underneath the plate mount for more airflow to the radiator. Once I got the system fully bled out, the car has gotten to just below the half mark when sitting for a while but usually sits just past the 1/4 mark while driving. I guess my "issue" is that when my fan kicks on ( usually just past the 1/4 mark) it stays on until about 10 mins after I shut the car off. I wouldn't care except for the fact that the fan draws so much power; the voltage gauge goes down by almost a full volt (from 14ish to ~13) when it is on. It also sounds like there is a tornado in the front of the car which makes it hard to impress the German honeys in front of McDonald's( yeah, I'm cool
). Seems kinda pointless for the fan to be running when I am cruising down the A60 at 90MPH.Should I go with a hotter temp switch? Should I move the switch to the radiator? I have it in the tstat housing as I think that would give a better reading as to the true coolant temp. Thoughts? Insults?
