When putting the head back on the M30 setting the timing seems a little rough. The Bently says you are suposed to align the camshaft sprocket so that the key is in the lower left with the screws pointing directly up and down. I did that but I could not get the screws to line up exacly up and down. They are off by a few degress. If I go to the next link in the timing chain then they are under by a few degress. The difference seems to be rather large. There is about 10-12 degress between each link of the chain and where it sits on the sprocket. I got it on the closest one but is there are better way to set the timing. It just seems like this is a little imprecise for a BMW. I dont want to start it up and find out the hard way something was wrong.
Of course I am setting this will the block is top dead center and I did roll the engine over a few times and the timing remained "on". Is this just good enough I guess?
My e36 required the 1 NM of force on the timing chain to set the sprocket correctly. I guess that is the kind of thing I was looking for on this motor too.
